Catch Can install - should I drill the AOS a bit ?
I'm installing a cheap ebay kit for $20, should I drill the AOS out a little when I install the catch can?
I do NOT want to pull the AOS and drill, but I will if it is required. TIA |
That Guy
If your venting the catch can to atmosphere its probably not a bad idea. Not necessary on a recirc type.
I would consider going with a recirc type so you keep a proper vacuum on the crank case.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Thanks Techno. I am reciculating the line back into the J boot.
