Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
oil pressure light comes on randomly at idle
I have an 86 turbo with 112,000 miles and sometimes the oil pressure light comes on randomly at idle only. I've noticed this happens on very hot days (80F or hotter). The red exclamation lights up at the same time. The oil pressure will read 0psi and the engine will still idle. If given a tiny blip in throttle, oil pressure shoots up to 2psi and light goes away. While in gear, oil pressure is at 4-5 psi and the oil pressure light never comes on while reeving above 1200 rpm. Even at 750rpm the light doesn't come on unless it is very hot outside and the car is fully warmed up. I'm not driving the vehicle until I figure this out. I'm currently using 10w40 Valvoline high mileage. I used to use 20w50 Valvoline racing and never noticed this problem.
1986 Porsche 951
Old 06-07-2009, 05:42 PM
Oil pressure gauge reads in bar, not psi. 1bar = ~14.7 psi. if you had 1psi of oil pressure you'd be in trouble.
I'd switch back to the heavier weight oil.
switch to something recommended by Porsche like brad Penn. tons of oil threads recently...
Old 06-07-2009, 10:47 PM
Super Moderator
nize's Avatar
yep. you're 10w40 oil is hurting the motor. use brad penn 20w50.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 06-08-2009, 09:17 AM
your average wrencher...
brad penn huh? good stuff there. X2
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 06-08-2009, 10:27 AM
Send a message via AIM to bjd34
You can stick with Valvoline. I use the synpower 20-50 or VR1 20-50, both with ZDDP additive.
Old 07-01-2009, 06:17 AM
Architect / Car Guy
carlege's Avatar
Send a message via AIM to carlege
Any one think there could be a corellation between Using lighter weight oil and Rod bearing failure?
Looking Forward to getting my First "car" Porsche 951
Old 07-01-2009, 06:54 AM
i'd honesty say its possible, but more for oil additives. for older engines(i say like obd 1 and earlier) you need to use the oil with the zinc/phosphorus additives. newer oils today are so bland in what they put in today, also newer engines have much tighter tolerances and require a lower viscosity oil or even a synthetic at that. older ones have much more clearance around the bearings and were not made at such a tight tolerance. but then you have to thing about what is being plugged up then(like your pcv ventilation) when the oil is a vapor and what makes sludge and such. then its to what oil brand you use....then to who's gas you run.....its just a lot of factors but the main one would be maintenance. I keep up on mine just to avoid any unnecessary headaches...
just my opinion
1982 931 *project*
Old 07-01-2009, 09:56 AM
choinga's Avatar
yeah - brad penn 20w-50 is the goods...very high quality oil with the ZDDP this engine needs (don't let people tell you it doesn't - it does). My PO used Valv synthetic and switching to BP solved all my weird oil pressure issues...now it's money (well, once I replace my oil pressure sender which died a couple days ago...)
Old 07-01-2009, 05:56 PM
All Spooled Up
Although I do recommend using 20W-50 oil, if the OP light starts to rear it's ugly head with 10w-40, that indicates the engine has wear. To stop the wear (obviously, you can't go back from "where" the wear is now without rebuilding), start using teflon (or other) based engine treatments with at least every other oil change. Make sure what you use claims to treat the engine, not the oil. And never go more than 5K between oil changes. Once wear starts, it continues at an accelerating rate.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 07-07-2009, 07:42 AM
TexasBlake's Avatar
I thought you were a strictly Mobil 1 40 weight Euro Blend guy?
Old 07-07-2009, 01:38 PM
lowbob84's Avatar
So, I run Mobil 1 synthetic 10W30 for high mileage cars.. but like most people, I don't want to do anything thats going to hurt me more in the long run than help. So where would I go to purchase this Brad Penn Oil?
Old 07-07-2009, 05:33 PM
http://www.bradpennracing.com/ my machine shop carries it....maybe a local performance shop?
1982 931 *project*
Old 07-07-2009, 05:37 PM
