All Spooled Up
Will stock FPR do 3 bar, or close to it?
Stock fuel pressure is supposed to be 33-39psi, with mine being right in the middle @ 36. But since I am getting some knock counts @ WOT with the perf mods that I have installed, I would like to try raising it up to the 40-44psi range to see if that helps. What is the highest nominal (no vac) pressure that a stock FPR can be adjusted to?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
it's a 2 1/2 bar reg and not adjustable. 2.5X14.7=36, where you are.
3bar x14.7=44.1, where you want to be. if you went to bigger injectors(not listed), not enough motion lotion. many mods require more fuel to operate correctly.
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
All Spooled Up
Ok, I think I do need 1 then. I thought that the nutted set screw on that diafram looking thingy that is right in front of the fuse box was for adjusting fuel pressure. Apparently that is incorrect. But then, what IS it for?
I posted a WTB for 1 in the classies, but so far no response. And on ebay, there are none currently listed that are 3 bar. Where can they be had?
Lindsey Racing sells 3bar FPR
Architect / Car Guy
Looking Forward to getting my First "car" Porsche 951 |
All Spooled Up
I have autothority mass-air chips, and don't know if they "require" 3bar, as I purchased the setup used, on ebay, without paperwork, other than a single "installation instructions" sheet, which could be done without, anyways. But with my free-flowing intake and exhaust mods, along with running 1.1bar of boost @7krpm, I have worries about going lean, especially if I get some bad fuel. I actually don't want to go this route, because it will hurt my fuel economy, especially during warm-up, when it is at it's worst, anyways. I do have a Vortex FMU, but it is straight-up 10:1, which isn't going to work. What I would REALLY like to get my hands on, is a rising-rate FPR, that can be set to be linear (2.5bar) up to a certain amount of boost - say around 10-12psi, then go rising-rate above that. But I have yet to see such a device available for these cars. Does any1 know if they can be had, and, if so, where?
i guess you have to decide which is more important, sacrificing fuel economy/3 bar or going lean at 7K.
Architect / Car Guy
either way he is going about it all wrong. You need to have in place After market boot gauge and AF wideband before you start adding stuff. Thats how You blow head gaskets and ruin engines. Being able to monitor those simple things can atleast give you an insight to how the engine is set to act
All Spooled Up
I am sure I'm not going too lean. But due to the variations in fuel quality, I kinda feel more "secure" going by knock counts, rather than stochiometric ratios. I don't see the necessity for an aftermarket boo(s)t gauge, when there is one already built into the car. I basically hate to clutter-up the clean stock look with redundant aftermarket stuff. It is never going to see track use, and, like I said, there are no additional aftermarket performance improvements going into it, so I don't feel the need to get too out-of-hand with extra stuff. I just want to increase my "fuel" safety margin a little bit, from where it is now.
Architect / Car Guy
All Spooled Up
Also, I just found out that autothority MAF calls for the use of a 2.5 bar FPR. Time to start considering a different approach, regarding high boost, high rpm, WOT enrichment.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) Last edited by wild man; 08-31-2009 at 08:34 AM.. |
Architect / Car Guy
ok do what you will.
your average wrencher...
[QUOTE=wild man;4867637]Given the choice... I think I would be more inclined to sacrifice fuel economy. But does any1 make a chip tailored for autothority MAF, AND a 3bar FPR, in an S? There would be no loss of fuel economy in that case.
as for chip in the S, i believe both the S and non-S are identical except for the turbo being a k26/8 vs. the 26/6. i think chip tuning is just based on mods. (exhaust, wastegate setup, intake, turbo, FPR, injectors, MAP/MAF/AFM, displacement) roughly...
1982 931 *project* 1986 951 Garrett turbo, Rogue Tuned (sold )1987 944S chipped, konis, rollbar (traded) 1979 924 total rebuild and blueprinted (sold) |
All Spooled Up
Does anyone "have the knowledge" of what the differences in the chips would be?
i know that some go by octane rating as well, some areas don't have 93, some have 93+...
Super Moderator
the s and non-s chips are not the same.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
All Spooled Up
But what IS the difference? Is it just a matter of a different fuel map to support full boost up to a higher rpm?
Architect / Car Guy
Yep i believe you got it
