-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   does removing the battery 'reset' the computer? (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/502040-does-removing-battery-reset-computer.html)
nynor 09-28-2009 07:02 PM
as the title says....
thanks,
darell
Rogue_Ant 09-28-2009 07:08 PM
On the 951? The 951 does not have a 'memory'. There is nothing to reset.
-Rogue
nynor 09-28-2009 07:53 PM
yes, on the 951. any other takers? i think rogue is correct.
still trying to sort another problem and i thought that *IF* the computer were 'reset'....
Rogue_Ant 09-28-2009 07:59 PM
I know I'm correct ;)
The DME does not have any non-volatile memory, besides the EPROM (which the DME can't change the code).
What kind of issues are you having?
nynor 09-28-2009 08:40 PM
failed emissions. high CO and high HC. which is EXACTLY the opposite of what i expected. i was expecting high NOx.
i think my air filter was plugged.
Rogue_Ant 09-28-2009 10:27 PM
How old is your O2 sensor?
nynor 09-28-2009 10:51 PM
two years, i think. at most, three years.
i pulled the k&n air filter and it was very dirty. i cleaned it and re-oiled it. back to the IM station tomorrow.
nynor 09-29-2009 04:03 PM
i checked the voltage coming from the O2 sensor: .3V at idle, dropping to .15 or so revved. i thought it was supposed to be around .8V at idle. can someone confirm?
Rogue_Ant 09-29-2009 04:04 PM
Hmm, O2 should cycle once the car is warmed-up and in closed-loop. It should cycle around .5v when in closed-loop.
Might have a bad O2.
nynor 09-29-2009 08:53 PM
yeah, i think it might be bad. i'll be replacing it tomorrow.
nynor 10-01-2009 04:05 PM
new O2 sensor reads .9V at idle and heated up. the 951 passed emissions, with significantly better numbers.
Rogue_Ant 10-01-2009 06:40 PM
Good news!
-Rogue
wild man 10-12-2009 06:56 AM
-Rogue
Conversely, you could say that it gets reset every time the ignition is turned off.
Rogue_Ant 10-12-2009 01:30 PM
Eh - semantics. The 951 does not have a 'fuel trim' or other resident memory feature...
-Rogue
wild man 10-12-2009 04:00 PM
-Rogue
Looks like, technically speaking, you got me on that one. What can I say? - nice job!
