Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
winter-hater club member
nynor's Avatar
does removing the battery 'reset' the computer?
as the title says....
thanks,
darell
"COOL PRIUS!" - Nobody Ever
Old 09-28-2009, 07:02 PM
Rogue Tuning
Rogue_Ant's Avatar
On the 951? The 951 does not have a 'memory'. There is nothing to reset.
-Rogue
-Joshua
www.RogueTuning.com
Old 09-28-2009, 07:08 PM
nynor's Avatar
yes, on the 951. any other takers? i think rogue is correct.
still trying to sort another problem and i thought that *IF* the computer were 'reset'....
Old 09-28-2009, 07:53 PM
Rogue Tuning
Rogue_Ant's Avatar
I know I'm correct
The DME does not have any non-volatile memory, besides the EPROM (which the DME can't change the code).
What kind of issues are you having?
-Joshua
www.RogueTuning.com
Old 09-28-2009, 07:59 PM
nynor's Avatar
failed emissions. high CO and high HC. which is EXACTLY the opposite of what i expected. i was expecting high NOx.
i think my air filter was plugged.
Old 09-28-2009, 08:40 PM
Rogue Tuning
Rogue_Ant's Avatar
How old is your O2 sensor?
-Joshua
www.RogueTuning.com
Old 09-28-2009, 10:27 PM
nynor's Avatar
two years, i think. at most, three years.
i pulled the k&n air filter and it was very dirty. i cleaned it and re-oiled it. back to the IM station tomorrow.
Old 09-28-2009, 10:51 PM
nynor's Avatar
i checked the voltage coming from the O2 sensor: .3V at idle, dropping to .15 or so revved. i thought it was supposed to be around .8V at idle. can someone confirm?
Old 09-29-2009, 04:03 PM
Rogue Tuning
Rogue_Ant's Avatar
Hmm, O2 should cycle once the car is warmed-up and in closed-loop. It should cycle around .5v when in closed-loop.
Might have a bad O2.
-Joshua
www.RogueTuning.com
Old 09-29-2009, 04:04 PM
nynor's Avatar
yeah, i think it might be bad. i'll be replacing it tomorrow.
Old 09-29-2009, 08:53 PM
nynor's Avatar
new O2 sensor reads .9V at idle and heated up. the 951 passed emissions, with significantly better numbers.
Old 10-01-2009, 04:05 PM
Rogue Tuning
Rogue_Ant's Avatar
Good news!
-Rogue
-Joshua
www.RogueTuning.com
Old 10-01-2009, 06:40 PM
All Spooled Up
-Rogue
Conversely, you could say that it gets reset every time the ignition is turned off.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 10-12-2009, 06:56 AM
Rogue Tuning
Rogue_Ant's Avatar
Eh - semantics. The 951 does not have a 'fuel trim' or other resident memory feature...
-Rogue
-Joshua
www.RogueTuning.com
Old 10-12-2009, 01:30 PM
All Spooled Up
-Rogue
Looks like, technically speaking, you got me on that one. What can I say? - nice job!
Old 10-12-2009, 04:00 PM
