Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
your average wrencher...
air intake
are these worth it?
air cleaner kit
OR
http://cgi.ebay.com/ebaymotors/Porsche-944-Turbo-Air-Velocity-System_W0QQitemZ150376212823QQcmdZViewItemQQptZMot ors_Car_Truck_Parts_Accessories?hash=item23031ee95 7
i know it will get some hot air from the engine bay and being after the IC, but will it help the turbo spool easier or any other benefits? I had one on my 944S and it sounded great, don't know if it helped power or not being it was already on the car.
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 11-29-2009, 10:12 AM
nobody runs one of these?
1982 931 *project*
Old 11-30-2009, 11:06 AM
Architect / Car Guy
carlege's Avatar
Send a message via AIM to carlege
looks like the lindsey racing stuff
Looking Forward to getting my First "car" Porsche 951
Old 11-30-2009, 11:38 AM
I ran a K&N knockoff cone filter for awhile with the stock AFM before I went to MAF and liked it alot. The hot air was never an issue and in my opinion the car breather much better than the stock air box with a K&N filter in it. I got a universal AFM 3" end and had to fab a bracket to hold the AFM up but I would recommend it. Just my 2 cents.
Old 11-30-2009, 03:18 PM
thanks zedsn, that's just sort of what i was looking for.
1982 931 *project*
Old 11-30-2009, 04:09 PM
dewolf's Avatar
I just removed my stock airbox because some clown broke the bolt holes and epoxied it back together. Had an SAAS (K&N knockoff) cone filter lying so I just whacked that on. Will report back later after a quick blast.
Okay...blast over with. It feels like it has made a difference to the power. It will spin the wheels easily in first when boost comes on, and then there's the 'flutter' you hear between changes. I like it.
In Heaven… the mechanics are German, the chefs are French, the police are British, the lovers are Italian and everything is organized by the Swiss.
In Hell…the mechanics are French, the police are German, the chefs are British, the lovers are Swiss and everything is organized by the Italians.
Old 12-01-2009, 10:36 PM
All Spooled Up
Sometimes you don't have the option NOT to buy one of those setups. The stock air boxes are so damn brittle, they break VERY easily. Mine was broken when I bought the car. But since I was not much of a fan of recycling the hot air from the IC, I ran (or should I say concockted?) a setup that deleted the J-boot, and routed the intake air similar to the way that the MAF setups do. But it was an extremely tite fit for the stock AFM. I actually had to flatten the post IC charge pipe a little bit to make it fit. Butt dyno results were definitely positive, as was throttle response. It wasn't long after that when I actually did make the switch to MAF.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 12-02-2009, 09:07 AM
hmm, got any pics wildman?
1982 931 *project*
Old 12-02-2009, 10:05 AM
All Spooled Up
For some reason, I had trouble locating this thread, so I started a new one. here it is:
Pic of J-boot delete.
Spoolup was definitely quicker, even with the constriction from 3" down to 2.5" @ the elbow, because that is still less of a constriction than the AFM itself.
Old 12-11-2009, 07:33 AM
BART'S 911 SC's Avatar
Here is mine from Linsey Racing installed after fuel line fire and melted stock air box,please don't ask...
Old 12-19-2009, 07:56 PM
cool, thanks man
1982 931 *project*
Old 12-20-2009, 01:41 PM
dewolf's Avatar
Cone style
Old 12-20-2009, 03:32 PM
Custom User Title
mikepellegrini's Avatar
Any increase in HP from "breathing eaiser" will be lost by drawing in hot engine compartment air. Depending on season, the air in the center of the engine compartment could be as much as 100F hotter than the outside air. And that will destroy any advantage.
The stock airbox draws in cool, outside air. The cooler the air, the more HP produced. That's why Porsche designed the system the way they did.
I've seen setups that have a snorkle attachment so you can have the cone filter and still get cool outside air. But that's the only way you can get an advantage from a cone filter.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 12-20-2009, 08:26 PM
Super Moderator
nize's Avatar
if you're gonna do it, do it right;
stock airbox + snorkle vs. free intake
here's some more info on why cone filters are probably not good for a 944;
k&n filters
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 12-21-2009, 04:17 PM
74goldtarga's Avatar
When I owned my Pantera I was active on a forum there and one of the guys on there posted a results of a test he performed using stock type filters by fram and motorcraft (I'm making up the comparo companies but you get the idea) and K & N - there were four total, one of which was K & N. Bottom line the K & N flowed a lot more particulate matter (dirt) which over time is really bad for your engine, and no significant (measureable) increase in air. For my money if I did use a cone it would not be a K & N, it would be stock type material. Just my 2 cents.
'74 911 Targa - Sold to the highest bidder
'87 944 Turbo - Fix for track addiction
'72 DeTomaso Pantera - Sold to the only real bidder
Old 12-21-2009, 04:37 PM
All Spooled Up
Are you saying the Spectre, or other brands that are 1/2 the cost of K&N are actually better filters??
And wouldn't filtering capability be a function of how "generously" one is oiled??
Old 01-09-2010, 07:20 PM
It is my understanding that the K&N type filters need oil to keep particles stuck to the filter itself because the material openings are larger therefore letting in more airflow thus increasing HP. The convertinal filters or dry filters are denser thus make it harder for the engine to suck in the air like the K&N type. Having tried both K&N and conventional the K&N whether K&N brand or a knock off is the way to go. My 2 cents.
Old 01-09-2010, 08:09 PM
