-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   The "final solution" for (AFM) intake upgrade. (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/526906-final-solution-afm-intake-upgrade.html)
wild man 02-17-2010 07:11 AM
ral weeks ago, I posted a pic of the deletion of the stock airbox/snorkle and J-boot. But that setup left one thing to be desired. And that would be the ability to draw air from somewhere other than the hot engine compartment. The germans are very "crafty" at coming up with solutions, but if I may brag a bit, I think I out did them on this one. First, you should probably read this post:
http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/515738-pic-j-boot-delete.html?highlight=j-boot+delete
And maybe this one too:
http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/513657-air-intake.html?highlight=j-boot+delete
Here are a pair of pics of the AFM with the cold air intake:
http://forums.pelicanparts.com/uploa...1266416455.jpg
http://forums.pelicanparts.com/uploa...1266416666.jpg
The flex pipe (with coupler) and the folded cone filter (which is too beat to use, now) were purchased at AZ (spectre brand). The filter was placed inside of the fender, with the rubber part sticking out into the engine compartment. It was mounted via sheet metal screws from inside the engine compartment. The plastic end of the alternator intake snorkel had to be notched out in order to fit the filter as I described. That is the dirty (lazy man's) method. One could opt for relocating it about an inch or so away from it's stock location, so as not to have to cut into it.
nize 02-18-2010 10:41 AM
wouldn't the corrugations in the flex pipe disturb air flow through the pipe?
ksudar 02-18-2010 04:06 PM
+1... you might want to check the air flow numbers on that contraption before anointing yourself smarter than porsche engineers.
wild man 02-18-2010 04:10 PM
I'm no expert in fluid dynamics, or anything, but it probably does. To what extent, would be the question. It IS 3" pipe though - compare that to the size of the stock snorkel end that goes into the fender. If you could get a piece of hardpipe bent for a good fit in place of the flexpipe, that would definitely be a better option. Since I am already well beyond using the stock AFM, I am just trying to put ideas out there for others to work with and perfect, for their own benefit.
wild man 02-18-2010 04:18 PM
Naw, all it takes is a little nerve, and maybe some narcissism.
Smiledr996s 03-09-2010 03:11 PM
Or this,
Which is soon to be for sale, as I go to a stand alone setup.
http://forums.pelicanparts.com/uploa...1268176279.jpg
Pm me if interested
running_cold924 03-09-2010 05:11 PM
mmmmm, looks good! lol hey, any more info about your upper strut mounts? kla's? you like?
