Injector Question
Does anyone know the peak and hold amps of stock 951 injectors? This is for my Megasquirt project.
I could also use the same #'s for NA injectors as well. |
Well, 951 stock injectors are ~4.5ohm. So at 14volts, that would be a little over 3.1 amps each.
The 944 injectors are ~2.5ohm. Which gives ~5.6amps each. -Rogue |
criminy. how do you figure this stuff out? electricity is a mystery, mostly, to me. i can use a multimeter for SIMPLE stuff, and usually kill a fuse in it, but that is the limit for me.
V = I * R
And those numbers are on the high - end. I was pretty much assuming max voltage, and not account for any V drop in the driver circuit. -Rogue |
For those that dont know:
Peak and hold injectors (less than 4 ohm) need a initial "burst" of energy to get them to open causing them to open faster than saturated injectors (10-16 ohm). The initial burst of energy (the peak) is then followed by a lower amperage that is sufficient to hold the injector open. Hence the name "peak and hold." I assume that those numbers are for the peak number? Does anyone know the hold number? This is usually between 1-2 amp. Thanks for the fast response!!!!! One other thing "V = I * R" V=Volts R= Ohms But I=Amps? I always used an "A" Since I have no formal training in electronics have I been doing it wrong? |
Yes.
I = Amps
And 1-2amps for hold should be fine. |
| All times are GMT -8. The time now is 12:05 AM. |
