-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Blink code tester doesn't blink. (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/557747-blink-code-tester-doesnt-blink.html)
wild man 08-08-2010 05:51 PM
I have a blink code tester installed, but not sure if it is working correctly. LR says that if you disconnect the TPS and drive around the block, or run the engine at over 1500rpm for more than 30 seconds, it should blink a 4-1 code.
But all I get when I disconnect the TPS is a steady on light - no blinking. Might I have a bad KLR?
Rogue_Ant 08-08-2010 05:57 PM
Your not shutting off the car correct? I doubt you have a bad KLR.
nize 08-09-2010 01:36 PM
are you sure you connected it correctly? steady on usually means you plugged it into power+ground instead of test+ground. :)
wild man 08-12-2010 05:30 AM
Even if it goes out after I plug the TPS back in?
