Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
winter-hater club member
nynor's Avatar
BOV orientation?
it seems that i remember some debate about this subject. what is the recommended orientation when installing the BOV?
"COOL PRIUS!" - Nobody Ever
Old 08-31-2010, 02:56 PM
That Guy
Techno Duck's Avatar
?? Same as factory. Which valve are you putting in, a piston or diaphragm type?
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 08-31-2010, 04:02 PM
nynor's Avatar
this one:
Pelican Parts - Product Information: 99-0609-100-M285
i installed it with the vacuum nipple straight up. is that correct?
Old 08-31-2010, 04:06 PM
All Spooled Up
That should be correct. Port opposite the vac nip goes to intake.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 08-31-2010, 04:13 PM
That Guy
Yes, install the valve the same way as the original Bosch one. The port on the side goes to the charge pipe, the bottom port goes to the j-boot.
Jon
Old 08-31-2010, 05:30 PM
nynor's Avatar
thanks, guys.
Old 08-31-2010, 06:26 PM
Super Moderator
nize's Avatar
i installed mine backwards, so that in case the vac line ever fails the bov will still work pushing against the spring pressure.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 09-01-2010, 07:26 AM
On Boost
Paulyy's Avatar
Nize, thats pretty smart, though i tried this on the same bov, but to atmosphere since i have no MAF i have a MAP sensor. it makes a ptshh sound then straight after stupid whissle sound.
86 952 GTX3076R, M-Tune, eBoost 2, CEP/JME cam, CEP head.
Old 09-01-2010, 08:15 AM
nynor's Avatar
SEE, i KNEW someone had a different idea about this!
Old 09-01-2010, 10:24 AM
Got Turbo?
PAUERMAN's Avatar
The action on the valve will not operate "accurately" if installed like Nize has it. Yes, the "muscle" air can push the valve open, but when the valve is being used, the spring rate is all that will close the valve and it will move too slow if the spring rate is below or close to the given boost setting.
The whistling that Paulyy heard is probably due to the valve dumping the charge air then coming to the closed position very slowly to where it whistles right before it fully seats. This slowed movment of the valve is because the charge air is still pushing on the bottom of the valve and the spring rate isn't strong enough to move it qiuckly to the closed position.
Vic Timpauer - www.pauertuning.com Mesa, AZ
944 Turbo S - Plug & Play Vi-PEC V44 EMS, GT3076R
DynaPack Dyno:
358whp/352lbft @ 18.5 psi 91 pump
438whp/430lbft @ 22.5 psi E85
Old 09-01-2010, 02:15 PM
Super Moderator
nize's Avatar
vic, due to the nipple vac line, i thought that when it was holding boost, the pressure on the bov action would be the manifold (or boost) pressure + spring pressure, thus there would always be enough pressure to close the valve, even with a weak spring.
conversely, when it's dumping i thought it would be vacuum + back pressure (or muscle air) which would jointly overcome the bov spring pressure.
Old 09-02-2010, 06:48 AM
nynor's Avatar
nize, i can see where you are coming from. i'll try it with that orientation and see if it makes any difference with A/F ration and/or butt dyno.
Old 09-02-2010, 09:37 AM
