Racer
944 Turbo Injectors
Anyone have any experience with Lucas injectors as a stock replacement for 944 Turbo injectors? Here is the part number:
Lucas D1680 - 95160611000 How do these compare to the Bosch 0280150803 or the stock Porsche part 95160611000? Thanks, Scott |
Location: In a dumpster behind Albertson's in Los Angeles County
Search this forum, someone recently posted a test with the stock injectors, lucas injectors and a couple of others.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
Racer
89-944NA,
I searched before I posted and saw that comparison. Unfortunately, the Lucas injector tested is of a higher flow rate than the one I am asking about. The one I listed is supposed to be a direct replacement for the stock part. Scott |
NY944Turbo
Just make sure they are low impedance or you need resistors.
All Spooled Up
Why would you go that route? Stockers have a better spray pattern.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
Racer
Super Moderator
i think you've answered your own question, you pretty much get what you pay for here...
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
One thing to remember when you start changing to a similar part from another manufacturer, they DON'T do the R&D that Porsche did when they designed and built the car. Cheaper is NOT always better.
If you need injectors, there are plenty of members on this forum that will gladly sell you a set at a decent price...I recently bought 4 cleaned and flow tested (done by WOLF) stock injectors for my 951 for $50, because they weren't supplying enough fuel to the sellers modified engine.
