-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Replacing 944T front turn signal (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/583591-replacing-944t-front-turn-signal.html)
ROBOD 01-04-2011 11:39 AM
I have to replace the whole left hand front turn signal assembly on my 1986 Porsche 944 Turbo. What do I have to do to access the electrical connection that is inside the front bumper? Can anyone give me a detail of how to do this replacement? Thanks.
944 Ecology 01-04-2011 12:09 PM
If you remove the front bumper cover, access to the electrical connection to the turn signal is trivial.
ROBOD 01-04-2011 02:11 PM
Thanks George can you give me some idea how I go about removing the front bumper cover?
Thanks.
kdjones2000 01-04-2011 03:59 PM
You should be able to reach up and behind the bumper cover and pull off the connector from its holding bracket.
You need to remove the batwing and lower pans to do this, but you shouldn't have to take the entire cover off.
I am replacing my radiator this week, so I should be able to shoot some pictures of what to do.
Good luck, Keith
