Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
using ATF in 944 trans with factory LSD
I have a 1983 944 with factory LSD in manual trans.
Question:
Should I use auto trans fluid for race application?
Old 01-17-2011, 09:46 AM
Owner R2 Racing
I use the swepco gear lube with a limited slip additive in my 86 944 race car
Old 01-18-2011, 09:59 PM
gearhead
For a racecar, limited slip additive is defeating the purpose. Limited slip additives are a NVH thing. They make the gearbox more slick, which is counter to the function of the LSD, and in the instance of the 944 specifically with it's anemic little 2 plate LSD that barely locks when it's fresh and new, you're really handicapping yourself here.
And under no circumstances put an ATF in that gearbox. Use a proper GL5 rated gear oil intended for transaxles.
Regards,
Matt Monson
Guard Transmission LLC
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-19-2011, 08:49 AM
commdiver's Avatar
ATF is a msnmer as some old school guys clean there transaxles and engines by running them with ATF for a few miles as low RPM's and ONLY as a detergent!!!
If your transaxle is in good shape and it has not sat unused for 10 years I would not run ATF thorugh it unless you really want to waste 4 qts of ATF and then another 4 qts of gear oil as you need to then flush with cheap gear oil and drain before you do a final fill with good Red-line 75w-90 or Swepco 201
'83 944 ROW zermatt silver/black, sunroof & A/C factory deleted, houndstooth sport seats, 7Q - 220 LSD short fifth, F & R 23.3 MM 951 M030 suspension, 16" fuch's, manual windows, club sport mirrors, Blk/Wht gauges, rear seats & all sound deadening removed, 968 rear wing, fiberglass hood & 937 F bumper
Old 01-20-2011, 09:01 AM
