-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   how to remove plug from air flow sensor (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/589057-how-remove-plug-air-flow-sensor.html)
quickster 01-31-2011 03:01 PM
this sounds dumg but i want to pull out the air cleaner assembly, how do you remove the plug from the air flow sensor, dont want to force it, looks like its held in by wire clips, do i pry those back
thanks
quickster
Techno Duck 01-31-2011 04:27 PM
Use a pick or a small flat head screw driver to push the two open ends of the wire clip apart, then pull the plug out.
quickster 02-01-2011 06:52 AM
thanks, got it
