Location: In a dumpster behind Albertson's in Los Angeles County
Turbo Coolant Leak?
While in the process of replacing my steering rack I have noticed a lot of the white flaky residue from coolant on the turbo/downpipe union. Does anyone know if this is going to require a complete turbo rebuild (no excessive end play at either end of the turbo) or just a reseal of the turbo coolant inlet? I still get plenty of boost, and have not noticed any other boost problems.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
The turbo coolant lines don't really need to be resealed...they use fittings that thread into either side of the CHRA, and then hoses clamp onto them. By turbo/downpipe unison, what connection are you referring to? Where the downpipe bolts to the turbo or where the downpipe bolts to the test pipe?
Darwin 1988 Porsche 944 Turbo S 944 Enhancement 3.1L SFR//TecGT//Vitesse//LEDA |
solved the problem....coolant was spraying from a pinhole in one of the turbo coolant hoses onto the turbo.
