Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
baypass valve question?
im going to replace my bpv and i didnt know if this was junk or to just go with the lindsey racing bpv???
BYPASS / BLOWOFF VALVE AUDI A4 A6 VW PORSCHE VORTEC - eBay (item 260742050751 end time Mar-04-11 11:21:56 PST)
Old 02-26-2011, 04:14 AM
All Spooled Up
Well, that's like 3X the cost of the stock (plastic) Bosch unit that it is supposed to be a direct replacement for. So I would have to assume that it is better. Out of curiosity, what does the racing unit go for?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 03-05-2011, 04:29 AM
Just because it is more expensive, doesn't mean it will be better. Many have used the LR piece without issues. Also look into Forge if you aren't wanting to replace it with stock. The LR unit is $128. (I'm not 100% sure, but the LR may be a Forge piece)
Darwin
1988 Porsche 944 Turbo S
944 Enhancement 3.1L
SFR//TecGT//Vitesse//LEDA
Old 03-05-2011, 07:37 AM
Send a message via AIM to TheCooler
LR sells a champion motorsports diverter valve. I believe that champions DV is actually a forge valve. The LR valve is much better and is made of metal! It contains different metal springs to adjust it instead of made of plastic with a rubber diaphragm which can wear out or crack easily.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 03-09-2011, 05:49 AM
I've got a Lindsey one, mine is a Forge piece, very happy with it so far.
Old 03-09-2011, 11:48 AM
Got Turbo?
PAUERMAN's Avatar
I sell a billet recirculating valve made by MODE Engineering. It is their design that the Forge units are modelled after. This is a factory replacement piece and it includes a removable 90 degree elbow piece (not in picture) that allows the vacuum hose of attach from the side.
Vic Timpauer - www.pauertuning.com Mesa, AZ
944 Turbo S - Plug & Play Vi-PEC V44 EMS, GT3076R
DynaPack Dyno:
358whp/352lbft @ 18.5 psi 91 pump
438whp/430lbft @ 22.5 psi E85
Old 03-09-2011, 05:40 PM
How much are they?
Old 03-12-2011, 06:31 PM
Contadino's Avatar
I did some research on this subject a while back
and decided to go with the Bosche '110 BOV. It is an upgraded version of the OEM valve and doesn't have problems of sticking pistons like the billet ones have, and doesn't need periodic maintenance (grease) like they do. Was quite a bit cheaper too.
Old 03-12-2011, 08:49 PM
