How do I get this intercooler out???
I can't figure out how to get the plastic duct out of the nose to remove the intercooler. I have the two forward-facing plastic plugs removed from in the duct, as well as the screws attaching it to the intercooler, of course.
What am I missing?
You don't need to remove the duct. You can compress it vertically at either end to tuck it down a few inches from the top of the intercooler. Then with some manipulation the intercooler can be pulled back and sharply up to come out. Its not a "delicate" procedure.
1987 951 ROW |
That Guy
As mentioned its a major PITA. Dont be afraid to crush the duct..
. Work out one side than the other, that's about the only advice i can give.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Your "enemies" are the two lower threaded pins. I posted about it in your "main" thread.
1990 S2 - mostly stock 1990 951 - 3.0 8V |
Thanks guys. I cringed trying to bend it enough to get it out, although I did see the factory relief slots on the sides that looked like they were there for exactly that reason. TThom, I did see that, thanks. I just didn't believe that was how it came out!
