-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Indicator Problems.. (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/612581-indicator-problems.html)
Memorex944 06-06-2011 04:08 PM
So I have this weird issue with my right front indicator. The light does not blink when the indicator lever is switched, but when I put the parking lights on, the bulb and light works. I know that there are 2 different connections that make both go, but I was wondering if anyone had an insight on this problem or if there are any ideas that pop into mind that I could try. I have tried to trace the wires to see if it is a wire problems but so far I have not found that to be the problem.
Nick
Grandad#3 06-06-2011 06:29 PM
Hi Nick, Change out the bulb and clean the light socket with contact cleaner and put on a dab of dielectric lube.
Cheers,
Larry
Memorex944 06-08-2011 11:30 AM
I have switched out the bulb and that doesn't seem to be the problem, I think it could be the contact so I will try the dielectric lube. Thanks for the suggestion.
