So I have this weird issue with my right front indicator. The light does not blink when the indicator lever is switched, but when I put the parking lights on, the bulb and light works. I know that there are 2 different connections that make both go, but I was wondering if anyone had an insight on this problem or if there are any ideas that pop into mind that I could try. I have tried to trace the wires to see if it is a wire problems but so far I have not found that to be the problem.
Nick |
Hi Nick, Change out the bulb and clean the light socket with contact cleaner and put on a dab of dielectric lube.
Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
I have switched out the bulb and that doesn't seem to be the problem, I think it could be the contact so I will try the dielectric lube. Thanks for the suggestion.
| Tags |
| front right , indicator , wire |
