Turbo vs NA Clutch
Can anyone confirm if the stock turbo clutch from the factory had the rubber insert or was it spring center? Thanks.
Tom 1987 911 Targa 1987 944 Turbo 1976 911S 1973 Mustang Mach 1 351C |
turbo was the center spring type..I just replaced mine
Bruce P. 2011 Cayman Base, LSD, Sport Chrono. 1988 951 totaled and missed ![]() "You're the best I ever had" --JJ Cale |
Thanks. So there is a better chance of a turbo clutch lasting longer than a NA based on that. How many miles did you get out of your clutch?
Turbo clutch disc and pressure plate diamiter is larger than a NA clutch and I would think everything else used to make the clutch setup is more heavy duty but the disc will wear out like a na clutch if abused too I would think. You would also have to use a turbo fork with a turbo setup and not the na fork as well as a turbo flywheel and turbo bellhousing. The ends don't seem to justify the need with a stock na 944 in my opinion.
In the Fires of Hell.....
Just buy a spring-centered replacement disc for the NA. The rubber-centered one is NLA anyway. Go aftermarket or OEM, and you should be fine.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
+1
KD has it right. rubber center no longer avail, as far as I know.
You can have a spring centered disk resurfaced as well..
South Bend Clutch - Dodge clutch kits and Kevlar Pilot Brgs. Dnya Max Clutch Kits for high performance. They have an entire range of surfacing materials.. they also offer cryo treatment of other clutch system components such as the pressure plate... |
All Spooled Up
To answer your question, I replaced the clutch at 108K mi. My prob actually turned out to be a cracked clutch fork, the plate was about 50% worn. Just had to do it all while I was in there!
All Spooled Up
I assume that you meant that it was the DISC that was 50% worn. Hopefully you cleaned and heavily greased the fork pivot bearings so you don't break another one.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
had to buy a refurb fork (951 part NLA) it came with new bearings which I greased well with Moly lube. You are correct, the clutch disc was 50% worn.
All Spooled Up
Is the refurb fork beefed in any way over an oem fork?
not to my knowledge. I was told they use a N/A clutch fork and machine off a small amount where the bearings mount. Evidently the fork shaft opening is a little wider for the 951. Although I didn't mic it out, it looked new and identical to the old one (minus the crack of course).
As an aside, what did you end up with on the turbo rebuild? K27 I assume? Mine is probly nearing the end of its service life @ 110k mi I expect
All Spooled Up
Yea, K27/8 with 3" exhaust and 3" intake from MAF to compressor inlet. But I still haven't installed the KEP2 pressure plate and 930 disc. I DO have some worries about breaking the fork with the KEP2, so I'd like to know what my options are for replacing the stock fork with a beefier one. If that option comes up dry, my last resort is to buy some "hard rod" welding rods, and perform the beefing procedure myself.
I went with the sach's PP and the 930 disc. You may want to call the folks at 944 online, they may be able help. I am unaware of any beefed up forks, sorry. I don't remember the deal on the KEP2, seemed like I read some sort of neg feedback on either the KEP1 or 2.
All Spooled Up
The neg is on on the 2, with it's 1 ton+ clamping force being the blame for a fair # of broken forks. Apparently nobody seems to think it's worth the effort to sell beefed-up forks, let alone come up with an aftermarket one for this extremely small market.
Super Moderator
there is only one place that makes a beefed up clutch fork, blaszak;
blaszak clutch fork photos
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Porsche 944S Club Sport
To all.
944 Clutch disc & Flywheel friction surface Na/S/S2 is 225mm Diameter Turbo is 240mm Diam Not Interchangable without Larger bell housing and proper flywheel trigger teeth. Later
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
I replaced my '86 951 at 165K. Mine probably had a bit of like, but less than 20%. My problem was a bad throwout bearing. It wouldn't turn - no noise, just felt like it was filled with peanut butter. It got replaced along with rear engine seal, clutch fork bearings, shaft, etc.
