Porsche Junky
A Flat 6 Guy Enters The Realm of 951's.....
The title says it all...picked this up this weekend...Car has these mods and I'm a newb when it comes to 951's....
Lindsay racing ceramic coated exhaust Boost controller (manual) Test pipe Hybrid turbo (k/26/8) Cup clutch Banjo Bolt Raceware head studs Wide fire head gasket Custom Cam Shaft Refaced valve guides Polished intake ports Throttle body bored and polished Top end of engine re-built/ re- sealed High flow injectors Car is clean and pulls strong. Currently has stock AFM/Snorkle set up and Autothority chip set....I've been told there are better chip kits available out there...any suggestions Thanks
1986 930 RUF equipped |
Banned
sounds like a great machine as is, i'd just drive it until you figure out what you want to change! MAF or MAP would be my first move on engine mods.
Yikes you have a 73 with a 3.6 ? Zhit that must pull nicely. I had a 69E hot rodded with a 3.2. Get ready though, neither of those 911s will ever pull as hard as a 951 after 100 mph. Have fun!
How long did it take you to find the motor?
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
I would definitely consider something from this vendor. A lot of good reviews and he's a genuinely good guy who knows his stuff. Way more contemporary than Autothority...plus you get backup too.
Rogue Tuning - Home
Patrick Youtube 333pg333 86 modified 951 |
Porsche Junky
Thanks for your responses...that Rogue kit looks interesting.....
The PO had this car 90% track ready. Coilovers all around, big brakes all around, etc... I've been doing DE's in the 3.6 but this car just sorta fell into my lap and will become my new DE car....handling and turbo transition seem much more 'refined' than my 930, which is a hand full on the track.... ![]()
If I was starting all over again and wasn't going with a standalone, I'd use either a Rogue Tuning kit or Vitesse products. If you don't want to change turbos then I'd probably hedge towards the RT setup.
It's also very important to make sure you're using a suitable oil for trackwork. These cars have a propensity for spinning bearings. Since you're in Florida you should use a 20w/50 minimum with plenty of ZDDP. We use a 25w/60 down here in Sydney.
Porsche Junky
Thanks, I'm aware of the oiling questions in re: the 951, I've run Amsoil 20-50 in my 3.6 for the last 3 years...no problems...
I'm leaning towards the Wolf unit...
