-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   What part needed to get passenger power lock wrkin? (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/649856-what-part-needed-get-passenger-power-lock-wrkin.html)
TODDEROSSI 01-09-2012 07:28 PM
1986 951.
Put the key in the drivers door and the passengers door will unlock but not lock back. So, as I use the key to lock the drivers door the passengers door stays unlocked. Just quit working recently. Checked all fuses and they are not blown. Do I need a door lock accuator or door lock servo ? Did a search in Pelican Parts and this BBS with negative results. Where to get needed part?
Thks
Pettybird 01-09-2012 08:44 PM
lock and unlock the passenger door to confirm you can hear the solenoid running in both directions. if not, time to check wiring. if so, it's this:
Pelican Parts - Product Information: 944-537-511-00
89-944NA 01-29-2012 01:18 PM
+1 on Pettybird's post....this plastic connecting rod is USUALLY the culprit when one side of the electric door locks quits functioning. Pull the door panel and look at the solenoid, the connecting rod fits the end of the solenoid with a pin, and snaps over a ball on the door lock...somewhat of a PITA to chnage.
