Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Question What part needed to get passenger power lock wrkin?
1986 951.
Put the key in the drivers door and the passengers door will unlock but not lock back. So, as I use the key to lock the drivers door the passengers door stays unlocked. Just quit working recently. Checked all fuses and they are not blown. Do I need a door lock accuator or door lock servo ? Did a search in Pelican Parts and this BBS with negative results. Where to get needed part?
Thks
Old 01-09-2012, 07:28 PM
Rocket Surgeon
Pettybird's Avatar
Send a message via AIM to Pettybird
lock and unlock the passenger door to confirm you can hear the solenoid running in both directions. if not, time to check wiring. if so, it's this:
Pelican Parts - Product Information: 944-537-511-00
'89 951S, Velvet Red
Plymouth Superbird, Corporation Blue
Plymouth Superbird, Blue Fire Metallic
Old 01-09-2012, 08:44 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
+1 on Pettybird's post....this plastic connecting rod is USUALLY the culprit when one side of the electric door locks quits functioning. Pull the door panel and look at the solenoid, the connecting rod fits the end of the solenoid with a pin, and snaps over a ball on the door lock...somewhat of a PITA to chnage.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 01-29-2012, 01:18 PM
