-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   944 turbo doesn't turn over (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/668843-944-turbo-doesnt-turn-over.html)
944racecar 03-30-2012 06:03 PM
I have a 944 turbo it will not turn over.. New battery everything else works . Turn the key and nothing .. Could it be the dme relay ..
Thank you if somebody could help
Techno Duck 03-30-2012 08:30 PM
Check ignition switch.
944racecar 03-31-2012 04:12 AM
K thanks ...when I turn the key everything else works but it will not crank
kdjones2000 03-31-2012 08:41 AM
Sounds like the starter solenoid has died. No clicking noises?
944racecar 03-31-2012 05:42 PM
Nope none..
Techno Duck 03-31-2012 08:05 PM
If you dont get anything from the starter its probably the ignition switch. Ive had this exact problem before.. everything worked just the car wouldnt crank. Left me stranded in a tiny ass parking lot once.. luckily my friend came by and was able to help me get it pop started with a 20ft stretch going uphill.. had to jump into my car dukes of hazard style. :).
If the solenoid is dead, you will still hear a whirring sound from the starter but it will not engage the ring gear. Bench test the starter to rule that out or use the procedure on Clark's Garage to check the ignition switch.
Edit - Clark's procedure..
http://www.clarks-garage.com/shop-manual/elect-17.htm
kdjones2000 04-01-2012 07:22 AM
If you were doing any work up near the brake booster it could also be the white plug up there became disconnected. The wire to the solenoid is part of that 2-wire connector.
