Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
944 turbo doesn't turn over
I have a 944 turbo it will not turn over.. New battery everything else works . Turn the key and nothing .. Could it be the dme relay ..
Thank you if somebody could help
Old 03-30-2012, 06:03 PM
That Guy
Techno Duck's Avatar
Check ignition switch.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 03-30-2012, 08:30 PM
K thanks ...when I turn the key everything else works but it will not crank
Old 03-31-2012, 04:12 AM
In the Fires of Hell.....
kdjones2000's Avatar
Sounds like the starter solenoid has died. No clicking noises?
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-31-2012, 08:41 AM
Nope none..
Old 03-31-2012, 05:42 PM
That Guy
If you dont get anything from the starter its probably the ignition switch. Ive had this exact problem before.. everything worked just the car wouldnt crank. Left me stranded in a tiny ass parking lot once.. luckily my friend came by and was able to help me get it pop started with a 20ft stretch going uphill.. had to jump into my car dukes of hazard style. .
If the solenoid is dead, you will still hear a whirring sound from the starter but it will not engage the ring gear. Bench test the starter to rule that out or use the procedure on Clark's Garage to check the ignition switch.
Edit - Clark's procedure..
http://www.clarks-garage.com/shop-manual/elect-17.htm
Jon
Old 03-31-2012, 08:05 PM
If you were doing any work up near the brake booster it could also be the white plug up there became disconnected. The wire to the solenoid is part of that 2-wire connector.
Old 04-01-2012, 07:22 AM
