Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
ERAU944's Avatar
Send a message via AIM to ERAU944
Porsche Crest Check your fuel hoses!
After my last fillup I got a gas smell around the back of the car. I crawled underneath to see fuel dripping every 20 seconds or so. This was the culprit, the line that goes from the filter to the hard line on the pressure side.
Check your lines guys, they're getting pretty old and there are too many stories about burned-down 951's. Everyone changes the lines on the fuel rail pretty religiously, but make sure your lines in the back are good!
Of course, I also replaced the filter. WYAIT...
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 07-24-2012, 05:54 AM
That Guy
Techno Duck's Avatar
Replaced mine earlier this year, looked exactly the same!
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 07-24-2012, 08:29 AM
tedg04's Avatar
Sound advice guys. I'm planning on the fuel filter soon, anyone have a part number for the hose as well?
edit - the part number for the under hood line would help me out too - I need to do that one at the same time.
Old 07-24-2012, 08:39 AM
ERAU944's Avatar
Here's the hose mentioned above: 951.356.047.03
I can't remember the over-the-rail hose numbers... next replacement I'll be doing Rennbay replacements.
Old 07-24-2012, 09:43 AM
That Guy
This is the damper line on the fuel rail, AKA the biggest fire threat.
944.110.413.02
Its also not a bad idea to replace the feed and return lines for the fuel rail. I would just go with the many aftermarket options available, but only use the kits that use COMPRESSION fittings at the hardlines, Dont use anything that makes you use a fuel injection clamp other than at the regulator (like how it is factory).
Jon
Old 07-24-2012, 10:20 AM
Pete R's Avatar
This was mine....(posted a year or so ago). Looked perfect from the top
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 07-24-2012, 11:18 AM
txhokie4life's Avatar
Our 924S had the same cracked hose when we pulled it.
On my 951:
I'm in the process of switching mine to steel braided AND putting fire sleeve & tape over it.
Maybe overkill -- but I'm not taking any chances.
mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 07-24-2012, 12:32 PM
Architecture & Porsche's
I re-did my damper line on saturday: used -6an Aeroquip hose: tape & cut, used EFI hose clamps over each end: perfect. Let's see that sucker burst!!
Mike, .028 on those plugs buddy.
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 07-24-2012, 12:55 PM
BoxsterGT's Avatar
Porsche Crest
I make this fuel jumper or damper hose assy.............
as well as others like this that goes to the fuel rail........
I have the correct fittings for the 95135604703 as well.....
All I need is the actual hose length from a fellow Pelican and I will post the results.
Len
Old 07-26-2012, 02:20 PM
