-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   How to disable "check oil level light" (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/737419-how-disable-check-oil-level-light.html)
quickster 03-05-2013 02:09 PM
I have a 1987 944 turbo and would like to disable the check oil level light that comes on every several months. I understand you need to short out the white with yellow stripe wire that comes from the sender unit to the dash. You can short it at the sender unit or under the drivers side dash. Can someone tell me how to do this.
thanks
quickster
1987 944 turbo
AaronM 03-06-2013 09:49 AM
Is it coming on when the oil level is not low?
quickster 03-06-2013 10:07 AM
of course not, i am vigilant on maintaining proper oil level
nize 03-06-2013 03:39 PM
if it's working properly, and you're vigilant on maintaining proper oil level, you should never see that light come on anyway. so i have to ask, why would you want to disable it?
333pg333 03-06-2013 04:01 PM
+1 ??
quickster 03-06-2013 04:23 PM
think about it, it comes on despite the oil level being correct, obviously there is a fault somewhere most likely in the instrument cluster ($$$$) and because I dont want a constant warning light on for something I know is not a problem, hense I want to disable it....
get it, got it, goooooood
AaronM 03-07-2013 02:33 PM
Originally Posted by quickster (Post 7312340)
of course not
Here you say that it is NOT coming on when the oil level is correct.
Now you're saying the opposite.
Which is it?
nize 03-07-2013 03:55 PM
i think what he meant was that the light is always on, regardless of oil level.
if this is the case, it's probably the oil level sensor, which is a very easy fix. you literally unscrew the old one and screw the new one in. this is a relatively reliable part, so it is more likely that you have a bad/frayed wire connection near there, which is more common.
this is the part:
Pelican Parts - Product Information: 944-613-150-00-M100
quickster 03-07-2013 04:38 PM
yes the light will sometimes just come on by itself even the oil level is correct, which i check on a regular basis, if you check my profile for old pictures you will see the car is well taken care of. Whats weird sometimes i would mess with some wires on the passenger side red wire from radio, and light would go out and stay out for a time. I have replaced the oil level sender, made no difference. Now I have gone through all the ground and have cleaned them except for the one i get to when i put the car over our grease pit. I think its probably in the printed circuit board unless i luck out and its in one of the grounds i clean up, also recheck the wires near the sender and oil pressure switch. If all this fails I will just ground the oil sender wire to chassis.
thanks
quickster
AaronM 03-07-2013 04:49 PM
That doesn't square with his comment about it coming on "every several months" though. It's apparently on sometimes and off other times.
Still probably points to the sensor though, I agree.
motorscuba 03-10-2013 03:39 PM
If all that fails you might want to look into the oil pump. A faulty pump can send the oil light on also.
