Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
87 Turbo front struts
I would like to replace the inserts in the front struts.
I haven't figured out if there is a way to remove the front calipers without having to disconnect the brake lines. These are rigid unlike other cars with flex hoses.
Thank you in advance for any responses and advice.
Raulg
Old 07-07-2013, 02:42 PM
968 GUY's Avatar
87 turbo???? Are the struts stock? If so, I do not believe there are inserts.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 07-08-2013, 05:38 AM
geoffbaltz's Avatar
Do you have a pic you could post? This sounds strange to me....
Geoff Baltz - St. Louis Region PCA
Board Member/DE Chairman
PCA HPDE Instructor
Old 07-09-2013, 11:08 AM
Keep looking. There is a flex line to the caliper, otherwise when the wheel moves, it would break a totally fixed line.
Old 07-10-2013, 05:01 AM
I will try to take a picture and post it here.
I saw a rigid line from the caliper to the strut. I think there is a flexible hose from the strut to the car body.
I will double check. My concern is whether the rigid line from the caliper to the strut needs to be removed to work on replacing the strut.
I found replacement struts equal to the originals but they are pricey. I found information here in this forum about modifying the original struts to accept new inserts. It is more economical however there is labor involved.
Thank you
R.G.
Old 07-16-2013, 09:53 AM
I may have misspoken. I should have said there is a flex line somewhere between each wheels suspension point and the caliper. IIRC, the way the hard line sits in the strut, there is a locking clip holding it in on the hard line side. I think this would make it tough to R & R the struts with the line in place.
Thank you
R.G.
Old 07-16-2013, 12:08 PM
Look carefully at the flexible-hose to hard-line junction and how it's attached to the strut-bracket. It is not a round hole through a square-bracket. The bracket is actually open on the outside (C-shaped). There is a thin sping-clip that slides like a guillotine down parallel to the bracket from the outside (also C-shaped facing the other way). The clip slides into a groove in the hose-to-hard-line joint. The two opposing C-shapes encloses the flexible-hose/hard-line junction and captures it to the strut.
Use some pliers, grip the bent outside-edge of the sping-clip and slide it away from the hole and the caliper can be removed from the strut without undoing the hoses.
Old 07-17-2013, 05:15 AM
DannoXYZ,
Thjank you for your reply and the photo. That explains it.
This is the information I needed to then take the struts out and replace them.
I appreciate the help.
My car has the original struts and I am considering buying a kit to drill the tubes and install the inserts rather than replace with the exact same thing.
Thank you
R.G.
Old 08-01-2013, 06:37 PM
DannoXYZ,
Thank you for your reply and the photo. That explains it.
Thank you
R.G.
Old 08-01-2013, 06:38 PM
Are you replacing with KONI or KYB? Make sure you torque the bottom strut insert bolt good. I used non-permanent loctite as well. I had one come off after few hundred miles and cause a front end clunk from the strut sliding up and down in the housing.
Old 08-27-2013, 12:41 PM
