just added AFR gauge and have questions
Just added an AEM widebeand to my bone stock 86 951 along with an aftermarket boost gauge to start getting a good baseline an understanding of my engine prior to future modifications.
At WOT between say 5-6K RPMs I see it fluctuate between 11.8 and 12.1. sometimes as high as 12.2. seems a bit lean from my searches. Should I concerned with readings above 12? Should I be onsidering fqs switch adjustment or a 3bar regulator or is all ok as is Help put my mind at ease. thxs |
If stoich is ~14:1 and rich is higher, I'd be very concerned. Turbo cars especially should go pretty rich on WOT. What does the O2 guide say?
In the Fires of Hell.....
You are basically capturing your current baseline, so I wouldn't worry too much about going above 12. Most of the guys who are stating that you should stay below 12 are pushing a lot more boost than your stock 10 psig.
You will notice that these cars go a bit leaner at the high end of the RPM curve, especially running the K26/6 and with the cycling valve in place. Porsche intentionally set the car up for longevity, so with the cycling valve in place and stock boost you will be fine. You just now know how your car is behaving... If/when you start pushing boost above say 15 psig then you should worry more about your AFR's and any lean condition. On a positive note, by not running pig rich on boost you are actually producing more HP ![]() Don't worry so much about it, and just use it as your baseline.... On a side note, how/where did you tap into your exhaust to place the WB O2 sensor? The stock location is a bit too close to the turbo for a WB sensor. The double-walled exhaust piping makes it a bit of a challenge (assuming that you are still on your stock exhaust).
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost Last edited by kdjones2000; 09-22-2013 at 03:35 PM.. |
Thanks for all the feedback. when I first hooked up power I made a mistake and hooked it up the ash tray light. Ha! Only worked with lights on and we all know how guages act a smidge different with lights in bcs of grounds
![]() I rewired and know Isee a solid 11.9 @ WOT ![]() Weld is in the top of the last bend just before cat as far from the turbo as possible but not "under" the car. |
I think that you have this backwards.
Alexander '75 911S Targa '86 951 SOLD |
Banned
richer is lower. WOT at full boost should be around 11.5
air to fuel ... air:fuel .... 14.7:1 is stoic ... often just called 14.7 Last edited by cockerpunk; 09-30-2013 at 08:18 AM.. |
Porsche 944S Club Sport
cockerpunk:
Yep, I agree, 11.5 is good for +4000k rpm and higher. Later...
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
