Checking Fauut Codes with Voltmeter
How do you use the volt meter to check fault codes. I know where to hook it up,but what setting should the voltmeter be on and what type of readout will it give to get the code?
I am having an issue in 5th gear at WOT at about 4k it is hitting a cutoff so I would like to check what code it is outputting. Thanks |
Why not just get an LED and use that for the blink codes? Easier than with a voltmeter.
| All times are GMT -8. The time now is 05:54 AM. |
