Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Checking Fauut Codes with Voltmeter
How do you use the volt meter to check fault codes. I know where to hook it up,but what setting should the voltmeter be on and what type of readout will it give to get the code?
I am having an issue in 5th gear at WOT at about 4k it is hitting a cutoff so I would like to check what code it is outputting. Thanks
Old 01-17-2014, 02:53 PM
In the Fires of Hell.....
kdjones2000's Avatar
Why not just get an LED and use that for the blink codes? Easier than with a voltmeter.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 01-17-2014, 05:34 PM
