Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Noise from oil filler while running with cap removed
I don't know if I'm being too anal about this but I have some noise coming from my oil fill tube while the engines running and with the oil cap removed. There seems to be a slight vacuum when I put my hand over the port and the sound ceases to exist. The noise is kind of high pitched and pulses with the engine. I have a video of it that I will upload when I figure out how to do it. Any advice or opinions would be much appreciated. Thanks
Old 04-05-2014, 05:35 PM
That Guy
Techno Duck's Avatar
This is normal, just a function of the pistons moving up and down.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 04-05-2014, 06:36 PM
Super Moderator
nize's Avatar
+1 normal.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 04-06-2014, 07:38 AM
Ok I figured as much I just thought I would ask since last fall I had a so called "944 restorer" look at it to buy and he said it wasn't normal. Of course this is my first car from the 80's so expected some noise but not a high pitch pulsating whine like this... Thanks for the piece of mind but I will upload the video anyways just as a precaution!
Old 04-06-2014, 04:26 PM
https://www.youtube.com/watch?v=-qPKBCHy3Cc&feature=youtu.be
The above link is a video of the noise i get, also is the ticking that loud normal? I assume it is due to the injectors and being a 26 year old car.
Let me know what you guys think.
Old 04-15-2014, 11:39 AM
In the Fires of Hell.....
kdjones2000's Avatar
That is a bit unusual.
Almost sounds like an air leak / vacuum leak coming from somewhere.
Look for some threads on the forum about how to check for leaks.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 04-15-2014, 02:58 PM
That's what I thought. Like I said before it's not a steady sound, it pulses/whooshes which you can't hear in the video. I will check into the vacuum leak theory when I get some time
Old 04-16-2014, 09:54 AM
