Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
333pg333's Avatar
Race car just about ready again
3.2ltr 16v racemotor installed. Just waiting on new billet intake to arrive to the shop. Finally finished. Then finish off the plumbing to the Electric water pump, make another harness for the new upgraded Motec ECU and we're ready for dyno. Finally. My shop is moving premises so there are some delays. Hope to see the dyno in about 1 month. Motor is pretty special. We're running the largest of the Borg Warner efr turbos (9180) twin scroll ext gates. Ideally we would have liked to reposition the turbo and gates but with RHD car (steering shaft) and having to retain stock firewall, it's pretty tight in there. Hopefully the modern twin scroll turbo helps with spool.
Patrick
Youtube 333pg333
86 modified 951
Old 08-19-2017, 04:00 PM
In the Fires of Hell.....
kdjones2000's Avatar
Wow, Patrick.
Looks awesome.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 08-20-2017, 05:43 AM
TrailRider's Avatar
Yeah, wow... amazing work.
Can you make another one of these engines for me?
'87 944 Turbo
Old 08-20-2017, 11:19 AM
333pg333's Avatar
Sure. Another motor is po$$ible.
Patrick
Youtube 333pg333
86 modified 951
Old 08-20-2017, 01:05 PM
333pg333's Avatar
Originally Posted by kdjones2000 View Post
Wow, Patrick.
Looks awesome.
Thanks. There are very few motors like this one. Based on precedence this should be good for North of 700bhp. Car weighs 1150kgs wet. Should be quite brisk!
Patrick
Youtube 333pg333
86 modified 951
Old 08-20-2017, 06:00 PM
Are you using the stock cam sprocket on the crankshaft? What kind of custom work was required to make up that double cam gear on the head, and get the valve timing correct?
It looks much more robust than the silly chain/tensioner setup in the stock head.
Also, are the wastegates electrically activated?
Old 08-20-2017, 06:30 PM
333pg333's Avatar
Most of the front of the motor has been customised. All custom cams and adj wheels. Billet water pump manifold. Billet custom crank hub and dampener. I haven't actually looked to see if it uses the stock cam sprocket but I doubt it. EDIT: Do you mean the sprocket in the centre of the cam? Then definitely no. No chain running in the middle. I think those wastegates actually have a sensor in them so you can run data, but they're not actually electronically activated.
Patrick
Youtube 333pg333
86 modified 951
Old 08-20-2017, 09:16 PM
