Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Ignition Timing Not Advancing
Does anyone know what controls ignition timing, from beginning to end? I'm guessing that it starts with the TPS, which signals the DME or KLR. I have also read that the knock sensor will effect timing advance. My mechanic says the ignition timing is not advancing. It seems to me that it should be a fairly small flow chart to determine what could be the problem(s), so a concise test plan can be developed. I doubt it's simple, but any ideas would be appreciated.
Old 03-06-2018, 01:55 PM
In the Fires of Hell.....
kdjones2000's Avatar
Look at the "DME Test Plan" for direction on this.
I would also get a new mechanic...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-06-2018, 05:20 PM
Main selector of ignition is AFM X RPM which determines which data-cell on 3D map is selected. RPM is determined by flywheel speed & reference sensors. TPS WOT switches to full-throttle 2D map. Think of that as the highest-load row on 3D map's "wall". Below WOT, TPS doesn't affect ignition at all. Here's fuel & ignition maps off a 951 (R.O.W map I think). Actual fuel & ignition values used is selected off X-Y coordinates off LOAD(AFM) X RPM scales.
Mechanic is probably old-style and thinks rotating distributor affects ignition timing (it doesn't). Find another more modern mechanic that knows how to use oscilloscope and computers for diagnostics.
Old 03-10-2018, 04:09 PM
soxnail's Avatar
Knock sensor input will retard timing about 3 Deg instantly. The ECU will then advance it again slowly. Give it (knock sensor) a tap with a socket extension adapter or something similar. NOT HARD !
If you have access to an oscilloscope hook it up to the output from the KLR to the DME pin 32 iirc
and you should see it. Or else a strobe on the ignition wire should show it too.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 04-02-2018, 04:45 PM
