Quick note,
When redoing the ball joint at the control arm, in the instructions it says remove the circular clip...be warned the spring under it will propel the bottom plate at a high velocity to parts un known. Sox http://forums.pelicanparts.com/uploa...1530633857.jpg |
The control on the passenger side was replaced (supposedly) about 15 years ago....
looks like it was rebuilt with a kit of some type. Has any one seen this particular rebuild of the ball joint ? and can I just leave the other zerk in there and just do the Rennbay rebuild ? The arm on the driver side was normal and rebuild went fine. Thanks and Happy Independence day. http://forums.pelicanparts.com/uploa...1530726120.jpg |
Just leave it in there, and go ahead. Mine were like that as well.
Thanks Keith,
The silver stuff was JB weld not aluminum. Already done. Sox |
| All times are GMT -8. The time now is 02:23 AM. |
