1992 Porsche 964 check engine light not illuminated
Hi all,
I recently purchased a 964 and found the check engine light to not illuminate when ignition is on. I suspected the previous owner had removed the light bulb - however the light bulb is still installed and works (i removed the fuel pressure gauge and checked it). I was unable to open the fuel pressure gauge after removing the 4 flathead screws. Any advice on how to do that? Also, could you think of other reasons why the check engine light is not working? Thank you!
Where are you/where is the car from? I believe that some RoW spec (M150/leaded gas models?) did not use the CEL. This functionality is supposedly not written into the chip on early models too.
1991 964 C4 Cabriolet - drop-top pylon destroyer |
Thanks for your reply.
The vehicle is a 1992 US model. |
It definitely *should* be working then! I would check the pin on the harness side before getting into the gauge. The CEL pin will either have continuity to ground to illuminate the light, or it will output +12v. You'll need to use the wiring diagrams to determine which pin on the harness is for the CEL.
Renowned for solder issues , do you have a multimeter ?
I do have a soldering iron, that’s why I tried to open the gauge, but I didn’t know how to. I just resoldered some joints on the analog clock as well.
You can put continuity to the pins on the gauge .
Are you getting a signal in the wires to the plug ? |
