Go Buckos
964 Steering Rack Questions
I'm building a 964 hot rod and I'd like to convert to a manual rack.
With some forward thinking, I'm already planning to convert almost everything in the suspension to 993 or aftermarket parts. With that said, would a non power rack from the 993RSR be okay on a mainly street driven car or is there another non power rack that my search terms couldn't find?
Heroes get remembered, legends never die. |
RS America had a manual rack.
IMO not worth it. I went with a manual rack for my track car and got tired of it changing it out for a power rack with electric cup car pump.
If you use 993 uprights and parts you will need 993 brakes and tie rods.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
Go Buckos
Thank you! Seems like it is the best solution.
And as far as the 993 uprights are concerned, I'm going with Big Reds and 993 or aftermarket footwork pieces for them.
