HVAC Motor actuator testing
I've posted a picture of the of one of the 2 HVAC Motor actuators that opens and closes the hot/cold air door flaps when you adjust the thermostat knob on the climate control unit.
This unit not working. Can they be tested and repaired? Don't have a wiring schamatic. Thanx |
Always Be Fixing Cars
Tore's site is the best starting point, this is one of many CCU DIYs, you will find more. https://www.bergvillfx.com/ccurepair
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
Year, make and model these servos are from?
I have a couple of used functioning units from a 993 @ $150 ea., + shipping and paypal fees.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
