Question 993 Won't pass smog!!!
Here is sunny California we have a law for smogging all 96 and newer OBD2 equiped cars. This law states that no more than 3 "non-continuous monitors" can be 'incomplete' . The only way I know of to reset these monitors is to run the car through a drive cycle. This consists of running at 50-60MPH, under 3000 RPM, with only a 2% change in throttle position for 2.5 minutes. UUUUUHH OK. In Los Angeles traffic this is close to impossible. Any leads on a tool or something that car reset this thing????
Old 05-01-2003, 05:21 PM
How about the runway at LAX, just kiddin'.
You may need to try it late at night on 5 or 405 heading out of the city.
Keith
Drive Hard and Fast
1991 Carrera 2 Targa
1972 911T Coupe
1971 914
Old 05-03-2003, 10:00 PM
Jeremy
I had the same frustrating problem. It seems almost impossible to activate the codes on your own since they require multiple repeated runs or the codes are cleared and you must start all over. Since this is technically an emissions problem, it may be covered under your warranty under the extended emissions warranty (7 years I believe). After attempting it myself, I brought it to a local Porsche dealer in TX who, after driving the car for 90 miles, said they were half way there. I quickly asked for the car to be returned. I then brought the car to a much more knowledgeable dealer who was able to activate all codes (while using the OBD scanner) after a half hour. They did not even charge for the service. I would suggest bringing the car to a dealer who is willing to use the ODB scanner while driving the car. The exact procedures are available via TSB.
Good luck
Jim
Old 05-06-2003, 11:20 AM
Thanks Jim. I spoke to a local dealer, and they had a suggestion. Go drive the car for 2 weeks and try it again! Some help they were.
Old 05-07-2003, 07:54 AM
