Question 1997 993 Won't Start
The car has been sitting on trickle charge for about a month. I was driving it a few times a week to and from work before this sitting period.
It cranks just fine and sounds healthy. Just won't start. It's low on gas; about 1/8 tank left. Any suggestions to get it to fire up?
Old 10-31-2021, 01:43 PM
First thing I would check is the DME relay, they often cause a no start and or will randomly shut the engine down.
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 10-31-2021, 02:21 PM
Hi Marine Blue - thanks for suggestion of DME relay. I’ll let you know if it’s the culprit.
Old 10-31-2021, 03:43 PM
+1 DME... If failed, replace with digital version for hopefully longer life. Always carry a spare, cheap tow avoidance insurance.
97 993 RSCS Tribute (Poliezi)
96 993TT (Yel/Blk)
17 AMG GLE 43 (Blu/Blk) - 08 smart fortwo (Yel/Blk) -99 JD F 911 (Grn/Yel)
89 944 T (Blk/Wht) sold
Old 11-01-2021, 09:00 AM
Thanks Kein - could you help with Brand and Part Number on the digital version of the DME?
Old 11-01-2021, 09:26 AM
Here’s a link to the website, you’ll need to decide which version you want: https://www.ftech9.com/new-products?category=SSR+%28Solid-State+Relays%29
I just picked one up for my 964 last week but haven’t had a chance to install it yet. I went with the standard non priming to stay with how the car was originally designed. I’m keeping my original as a backup in the car.
CURRENT:
Old 11-02-2021, 05:09 AM
Thanks again Marine Blue! The Diagnostics version is slick. Will most likely be ordering this one. Based on part numbers, non-primed seems correct for my car as well.
Old 11-02-2021, 06:32 AM
Marine Blue got to it first. FTech9... No affiliation, just a happy customer.
Me and all my 993 pals run FTech9s and many use the old analog as their spare. Not aware of any Ftech9 failures yet, been around for a 3+ years.
Also Jay's IMMO block is also a nice mode to lose the key fob 30-sec re lock "feature".
96 993TT (Yel/Blk)
Old 11-02-2021, 07:03 AM
Thanks Kein! Good to hear you agree that FTech9 is a solid option for the DME. And thanks for the time on the IMMO block - the relock feature is definitely annoying.
On a no start related note, I emailed a Porsche racing and street shop here locally, and they said it may be the crank sensor - have you heard of this sensor failure?
Old 11-02-2021, 09:07 AM
Yes that can fail out of the blue (old plastic), but harder to get to to replace and to remove/replace.
Went to pick up my 993 a few years back from a shop service, they drove it to the detail stall while I was there to give it a quick wash, then when they went to pull it out and give to me, it would not start. DME first thought, but a swap didn't fix, then on to crank sensor, fixed it.
96 993TT (Yel/Blk)
Old 11-03-2021, 08:36 AM
Thanks Kein - yeah, hoping DME not Crank Sensor - much more difficult to swap!! Thanks again for the help.
Old 11-03-2021, 10:44 AM
Well, it's not the DME. So, on to the 10X more difficult crank sensor. Does anyone have technical instructions for this fix? Could not find anything on this site. Thanks
Old 11-07-2021, 11:07 AM
https://rennlist.com/forums/993-forum/784293-adjusting-speed-reference-sensor.html
Discusses how to remove / and adjust.
Bentley Manual has how to remove / install, but doesn't reference any adjustment.
96 993TT (Yel/Blk)
Old 11-08-2021, 05:37 AM
Stop the parts cannon.
If you diy, invest on a pico scope.
View video at 6:00 to test speed and ref sensors
https://youtu.be/L1jJpLzshP8
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 11-08-2021, 07:05 AM
Thanks Kein and bazar01. I appreciate your feedback - it really helps.
Bazar01 - I think you are absolutely right - If I want to be a DIYer, I should have the proper tools - thanks for the link showing the Pico scope. Franny is a genius home mechanic!
Old 11-09-2021, 06:40 AM
fuel pump
Well, after me trying to figure it out and failing, I had a local shop diagnose and its a bad fuel pump. Not a terrible fix as far as cost, so should be back on the road soon! Thanks for everyone's input and help. I also purchased a pump-primed DME from Focus 9 Technology.
Old 12-02-2021, 06:20 AM
Next time do the MOST basic tests (Remember, an engine needs both spark & fuel);
1. Pull a coil wire and check for a spark.
2. Spray carb cleaner (fuel) into the air cleaner.
Dave
Old 12-02-2021, 09:52 AM
Okay
Sent from my TECNO CG6 using Tapatalk
Old 12-17-2021, 12:56 PM
Tags
1997 porsche , 993 , starting
