964 Rear bumper loose
Hey,
So I was just cleaning the engine bay when I noticed that the rear bumper was making a squeaking sound when I moved it.
I noticed that there was one self tapper missing under the bumper to a metal plate. It helped things but not totally as you can see in the video.
Any idea's or do I have to remove the whole bumper?
https://youtu.be/ojS-wMMLfEo
Regards
Alex
Old 02-20-2022, 08:30 AM
I'd get on my back and look upwards inside the rear bumper on both sides and wiggle it while there...might be obvious then. Could be that the bumper had beeen removed in the past and when re-assembled someone was not careful in putting back all the attaching hardware.
Old 02-20-2022, 08:39 AM
Engine electric blower pipe not fitting correctly
Hey,
Let me just stress I am a total newbie as this is my 1st ever Porsche so some terms or questions may seem a bit stupid but please bare with me.
So the car had a service and everything was checked before I bought the car, but seems to be somethings were missed.
As I hope you can see from the picture that the hose has a gap in it when it ws clamped with the jubilee clip.
Could this have caused any issue with the running of the car?
Is there anything I need to be aware of when removing this to correct the issue?
Regards
Alex
Old 02-20-2022, 08:40 AM
That clamp and that small gap is fairly common and has no impact on how the car runs, it’s strictly part of the heating system. The fan connected to this does provide some engine cooling so gaps do reduce the efficiency but overall it wouldn’t impact how the car runs, just the temp.
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 02-20-2022, 05:21 PM
Hey,
Is it difficult to remove and fit correctly, or just leave it as is?
Cheers
Alex
Old 02-21-2022, 10:08 AM
Originally Posted by Alexd12 View Post
Hey,
Cheers
Alex
Once the plastic piece has taken that shape I don’t believe you will be able to correct it easily, it would require you to likely heat it up and reshape it and then let it set. Hopefully someone else has also run into this issue and can comment if there’s a fix.
CURRENT:
Old 02-21-2022, 11:53 AM
Hey,
Cheers for this and maybe I will give it a go as I have nothing really to loose, but like you said it could be set like this now..
I suppose I don't even want to ask how much one it....
Cheers again
Alex
Old 02-21-2022, 09:00 PM
Somehow this thread got mixed up, so I will continue with the Loose rear bumper as the thread was meant to be.
So I jacked up the car to get a better look and it seems that there is a Aluminium plate which I presume is a heat shield is loose.
I am no expert but my assumption is that the plate is bolted, but the holes have increased in size and the bolt is no longer holding it. Or is it meant to be like that?
Here is a video https://youtu.be/jv1pn77DNYM
Here is a picture. Where ever is a bolt through the length of the plate is also the same.
If this is broken is this common and what is the fix other than buying a new one?
Is it just to pop rivet a plate over the hole?
Cheers and thanks as always
Alex
Old 02-22-2022, 11:14 AM
ahead of the curve
Jeff Burger's Avatar
[QUOTE
Alex[/QUOTE]
yes the aluminum heat shielding is not that robust , I bought some new pieces not that long ago from porsche but pretty pricey.
I don"t know what " the fix " is other than buying new but it looks like under a dollar's worth of USA fender washers would secure it ..... $10 if you use german washers
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 02-22-2022, 03:01 PM
Hey,
Cheers for your comments and it doesn't seem, or at least I can't see any cracks in it.
Pretty weak design in my opinion and I would expect it to have some thicker plate in those areas.
I have asked this question in another forum, but does it require the bumper to come off?
I did notice that a couple of the brackets at the back of the bumper are loose as well.
Cheers
Alex
Old 02-22-2022, 09:10 PM
So I started to look in to this and started the process of taking the bumper off, but just kept scratching my head as one article said remove the heatshied to get the bumper off..
So stupid question, but to get the bumper off do you need to remove the heat shield 1st?
Well I stoped removing the bumper and turned my attention to get those damn 4 bolts out.
So far 2 done and I will add new "Repair washers" in place of the old ones which I think will hold it.
Anyhow any advice or suggestions would be great.
Cheers
Alex
Old 02-24-2022, 12:25 PM
