-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Trying to access technical article on steering rack replace (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1119275-trying-access-technical-article-steering-rack-replace.html)
tshih 05-21-2022 06:16 AM
Having trouble viewing the images on tech article about replacing the leaking steering rack of my 993 1996 carrera. When I try to open the image I get forbidden 403 error message. How do I access these images?
OSC911 05-21-2022 07:48 PM
I have found that a lot of the tech articles on PP haven’t transitioned properly when they did the upgrade. It seem that the photos can’t load for some reason unfortunately. It is a real shame as the upgrade appears to be a downgrade.
Cobalt 05-26-2022 07:12 AM
What did you need to know. I just rebuilt a 964 unit but haven't installed it yet.http://forums.pelicanparts.com/uploa...1653574145.jpg
Pretty simple system just need to take your time to rebuild it. The early 964 racks were a little different and the new seal kits make some changes using an improved design shown above. I lifted the first pic from another site.
group911@aol.co 05-26-2022 09:39 PM
Anthony. Have you ever swapped a 993 rack into a 964?
Cobalt 05-27-2022 03:32 AM
I had considered it but haven't done it yet. I can't find a reasonable core to do the job and they are nearly $5k new.
group911@aol.co 05-27-2022 07:26 AM
I think I have a spare good 993 rack if you're looking. I always wanted to try one as they are a quicker ratio and definitely have a different feel.
Matt at Pelican Parts 05-27-2022 09:53 AM
I tried to look up the tech article:
https://www.pelicanparts.com/techarticles/pcar_com/993_steering_rack_replacement.htm
But on my end the images will not load either. I am told we are working on getting the image links fixed so at least know it is in the works. With some searching I found this thread which has links to an article by p-car with images, which is also the source of our DIY article. You can find that thread linked here:
http://forums.pelicanparts.com/porsche-964-993-technical-forum/737603-removing-964-steering-rack.html
Hope this helps!
-Matt
