Trying to access technical article on steering rack replace
Having trouble viewing the images on tech article about replacing the leaking steering rack of my 993 1996 carrera. When I try to open the image I get forbidden 403 error message. How do I access these images?
I have found that a lot of the tech articles on PP haven’t transitioned properly when they did the upgrade. It seem that the photos can’t load for some reason unfortunately. It is a real shame as the upgrade appears to be a downgrade.
What did you need to know. I just rebuilt a 964 unit but haven't installed it yet.
![]() ![]() ![]() Pretty simple system just need to take your time to rebuild it. The early 964 racks were a little different and the new seal kits make some changes using an improved design shown above. I lifted the first pic from another site.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
Anthony. Have you ever swapped a 993 rack into a 964?
I had considered it but haven't done it yet. I can't find a reasonable core to do the job and they are nearly $5k new.
I think I have a spare good 993 rack if you're looking. I always wanted to try one as they are a quicker ratio and definitely have a different feel.
Administrator
I tried to look up the tech article:
https://www.pelicanparts.com/techarticles/pcar_com/993_steering_rack_replacement.htm But on my end the images will not load either. I am told we are working on getting the image links fixed so at least know it is in the works. With some searching I found this thread which has links to an article by p-car with images, which is also the source of our DIY article. You can find that thread linked here: Removing 964 steering rack Hope this helps! -Matt |
