Front hat play to rotor
So while going through getting some front 993 brakes sorted I noticed that the hub/hat was loose from the rotor. There was maybe ~.1mm of play. Not much, but enough that I can feel it. I recently read that this amount of play is ok, but then I also read to torque it down to 6ft lbs. I have never worked with floating rotors before so any expert info on this would be appreciated. I also read that some replace the hardware and some don't. Unfortunately it doesn't look like anyone has a hardware kit to refresh that. Are these stretch bolts? Should I just clean them up and reuse?
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 06-27-2022, 07:34 AM
993 owners?
Old 06-28-2022, 06:46 PM
Bill Verburg's Avatar
Assuming you have stock 993tt front rotors then there should be no play at all, they are not floating they are hard bolted
Bill Verburg
Old 06-29-2022, 12:55 PM
Thanks Bill, yes they are 993TT ones. I reassembled and torqued everything to 6ft lbs, no more play.
Old 06-29-2022, 06:11 PM
