GRD GRD is offline
964 cut out while driving and would not restart
I was out today in my 964 and it just died on me. I tried to restart it and it has power but just won't turn over. Could it be the fuel filter or the fuel pump relay?
Old 09-14-2022, 02:34 PM
The Fuel Pump relay is always the first place to start when it randomly shuts down or doesn’t start up.
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 09-14-2022, 06:48 PM
Happened to me on my RS America. Turned out to be the Key. Nubs wore down, let Run Pin Open.
Used Spare, Fired right up. Changing the relay didn't help.
Old 09-17-2022, 04:29 PM
Good to know, can’t be common but certainly something to check. How many miles do you have on your RSA?
CURRENT:
Old 09-17-2022, 05:14 PM
Check out one of the relay. I forgot the name of that relay, but that relay needed to open up and
re-solder or buy a new relay. I re-soldered it and it works.
Old 09-17-2022, 06:30 PM
Newsboy's Avatar
Check to see if you have fuel. spark at the plugs.If both are not present, could be flywheel speed sensor.
Old 09-18-2022, 02:04 AM
170k miles. The Ignition Switch on my 1970 914-6 wore out and wouldn't engage the
starter. $600 to rebuild the switch, so they can be rebuilt, just pricy. I used Black Forest in San Diego
Good Luck
Old 09-19-2022, 11:41 AM
Relay
If it is your relay you might consider a solid state relay from ftech9 if your 964 is a coupe. For some reason they don’t work on a cabriolet. No affiliation. I went through two relays. I installed their ft9 a few years ago and no hiccups yet. Btw. Always keep a spare.
Old 09-19-2022, 02:20 PM
Cobalt's Avatar
I would start by checking the fuses to the DME and fuel pump if that doesn't do anything try replacing the DME relay. It sounds like the engine is turning so it isn't the starter.
I have had the switch at the end of the key column fail. It is a PITA but can be swapped out. It doesn't sound like the problem but the switch is designed to cut out the lights and in the case of a C4 or turbo the hydraulic pump when starting to eliminate excessive draw on the system.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 09-22-2022, 06:08 AM
Engine Cut Out
After Fuel Pump Relay, and Fuses - Next culprit is Fuel Pump
Old 09-22-2022, 09:06 AM
