-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   ODBII Code P1119 (http://forums.pelicanparts.com/porsche-964-993-technical-forum/113964-odbii-code-p1119.html)
addictionMS 06-07-2003 07:38 PM
ODBII Code P1119
anyone know what it means?
I know this so far
P=Power Train
1=Manufacturer specific
1=Emmission Management
19=???
thanks
Jim
mallen 06-07-2003 08:05 PM
Manifold Absolute Temperature Circuit High Input
Mark.
Lorenfb 06-14-2003 10:33 PM
Per the Porsche manual (OBDII), this code P1119
relates to the O2 before the cat. heater circuit #2.
Your car should have four O2s; two on each side,
each before and after the cat.
The heater circuit provides voltage to the O2 to heat it up
before normal temp is reached. Check your fuses or the
wiring.
Good luck
Loren
SYSTEMSC.com
addictionMS 06-23-2003 09:31 PM
thanks
Jim
