addictionMS's Avatar
ODBII Code P1119
anyone know what it means?
I know this so far
P=Power Train
1=Manufacturer specific
1=Emmission Management
19=???
thanks
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 06-07-2003, 07:38 PM
Manifold Absolute Temperature Circuit High Input
Mark.
Old 06-07-2003, 08:05 PM
Lorenfb's Avatar
Per the Porsche manual (OBDII), this code P1119
relates to the O2 before the cat. heater circuit #2.
Your car should have four O2s; two on each side,
each before and after the cat.
The heater circuit provides voltage to the O2 to heat it up
before normal temp is reached. Check your fuses or the
wiring.
Good luck
Loren
SYSTEMSC.com
Old 06-14-2003, 10:33 PM
thanks
Jim
Jim Hamilton
Old 06-23-2003, 09:31 PM
