89 C4 to C2 Speedometer: How to make it work
Hi,
Is there a DIY to make the speedometer work after converting the car from C4 to C2? Background: 1989 C4 speedometers are driven by the pulse sender from the gearbox. R24 Relay also doesnt exist in a 1989 to work in conjunction with R52 to capture the signal from the front left wheel sender after conversion. How have others made the speedometer work after a conversion. I have a R52 C2 relay, would I have to bypass some ABS wiring? Thank you! Mark |
The later C-4 ABS computer- the one ending in 01, picks up the signal from the left front wheel sensor like the C-2 does. Check the PET and see if that computer was a superseded number for the 89.
Thanks! |
