-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Alarm 964 turbo startermotor problem (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1153771-alarm-964-turbo-startermotor-problem.html)
spjuvern 01-13-2024 02:38 AM
I have had a long time problem that startermotor
don’t pull all times.
I have previously changed ignition switch and startermotor.
on a 964 turbo the cable goes straight no relay according to wire diagram.
anyone know it’s way and we’re the split at the Porsche alarm could be?
http://forums.pelicanparts.com/uploa...1705142316.jpg
jm993rs 02-14-2024 04:51 AM
Today my 964 but start the emergency lights and not start !!!
Last days when I open with the key times not open the other door ….. and when I input the key on the starter I see the 4 lights intermitent working …..
I down of the car return close the car …. And return open and is disconnected !!! And the car start without problem ……
And today I have the same step problem but never can stop the emergency lights and not start the car …..
I disconnect the battery and always when I return conect start the 4 lights emergency and the car not start engine 🙈🙈🙈🙈
Please I need help for where I can start to repair this problem !!! 🙏🏻🙏🏻🙏🏻
Cobalt 02-14-2024 06:38 AM
Do you have an aftermarket or 993 alarm installed> The 964 never had a key fob actuated alarm. That looks like the 993 alarm key fob. If so the 993 units are notorious for acting up this way. The capacitors leak and can create a short that acts like a ghost in the machine. Sometimes it works sometimes not. I would first check to see what you have installed.
