Remote sideview mirror switch / door trim
I am addressing some issues and want to remove the driver's remote mirror switch from the door panel Cover Strip. No problem removing the door lock bushing or the associated electronics.
However, the mirror control seems stubborn and the last thing I want to do is make things worse.
I've searched and come up empty on any, let alone the proper, method to disassemble this part.
TIA for any help!
If you can't explain it simply, you don't understand it well enough. - ALBERT EINSTEIN
Mostly lurking; always learning. - Me
Old 03-18-2024, 10:34 AM
Cobalt's Avatar
You are trying to remove it? Pull the knob straight up and there is a threaded nut on the top face you unscrew and it should come right out.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 03-18-2024, 10:48 AM
Thank you so much, Anthony!
Mark
Old 03-18-2024, 07:46 PM
Cobalt's Avatar
No problem. That is why these forums exist so we can all learn and help each other.
GL
Old 03-19-2024, 06:00 AM
